Xantia 1.9 d turbo axle onto a hdi?
Porkchop
Do ye think this would work? the d turbo in question is a 99 model, the hdi is 01. d turbo has drums and hdi has discs but would that matter? i'm sure the brake set up could be swapped?
Brigsygtt
citroenxm
- Fallen Hero
- x 70
All rear subframes from around 1997 are the same being fitted with the anti sink system!
ALL Hydraulic citroens, thats DS, GS, BX, CX, XM, Xantia ALL have disks at the rear!!
Theres ONLY 4 pipes to disconnect from the rear and then the WHOLE rear subframe cone come away as a COMPLETE unit!! Theres one to each end of the subframe, and two that goto to centre units!!..
4 Bolts hold the frame on! you'll need to remove the exhaust back box and possible the main pipe to remove the frame too...
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
addo
- Sara Watson's Stalker
- x 95
- x 5672
Xaccers
- x 188
Drum kit in the boot doesn't countaddo wrote:Paul, I have a "hydraulic Citroën" with rear drums.
DIY sphere tool
DIY sphere tool
citroenxm
- Fallen Hero
- x 70
Ive JUST Realised, The DS DID NOT have Disks at the rear, they were drums... ooopppppsssssscitroenxm wrote:All rear subframes from around 1997 are the same being fitted with the anti sink system!
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
addo
- x 95
citroenxm
- Fallen Hero
- x 70
Addo, I think the DS was always drums... it was the CX that introduced the Disks to the rears, then the GS then the BX, then the XM, then the Xantia.. in that introduction order
(Note: SM excluded, apart from the looks and the engines I do NOT know near enough about those machines)
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
