Xantia 1.9 d turbo axle onto a hdi?
Porkchop
Unread post by Porkchop »
Do ye think this would work? the d turbo in question is a 99 model, the hdi is 01. d turbo has drums and hdi has discs but would that matter? i'm sure the brake set up could be swapped?
Brigsygtt
Unread post by Brigsygtt »
d-turbo has discs at back mate, as far as im aware all the xantia's have rear discs.
97 Xantia 1.9 td lx with a/c (Daily, 172K, FOR SALE)
98 Xantia Hdi Lx with a/c (105k)
97 Renault Extra (c1j turbo 230+hp, 12.88@106)
91 Renault 5 Gt turbo (68k minter)
Porkchop
Better again! excellent stuff thanks for that!
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
All rear subframes from around 1997 are the same being fitted with the anti sink system!
ALL Hydraulic citroens, thats DS, GS, BX, CX, XM, Xantia ALL have disks at the rear!!
Theres ONLY 4 pipes to disconnect from the rear and then the WHOLE rear subframe cone come away as a COMPLETE unit!! Theres one to each end of the subframe, and two that goto to centre units!!..
4 Bolts hold the frame on! you'll need to remove the exhaust back box and possible the main pipe to remove the frame too...
Paul
A very sad...
1994 XM 2.1 d auto
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Paul, I have a "hydraulic Citroën" with rear drums. :wink:
x 5672
addo wrote:Paul, I have a "hydraulic Citroën" with rear drums. :wink:
I thought that ALL hydraulic Citroens had discs all round, with the possible exception of early DSs.
Xaccers
x 188
Unread post by Xaccers »
Drum kit in the boot doesn't count :D
DIY sphere tool
Porkchop
Thanks for all the help lads! :D
citroenxm
Fallen Hero
x 70
citroenxm wrote:All rear subframes from around 1997 are the same being fitted with the anti sink system!
Paul
Ive JUST Realised, The DS DID NOT have Disks at the rear, they were drums... ooopppppssssss :oops:
Paul
A very sad...
1994 XM 2.1 d auto
addo
x 95
Indeed. At least through to the "second front" they were rear drum braked.
Could be third front cars were 4W disc (excluding breaks?), but have never paid enough attention to be certain.
citroenxm
Fallen Hero
x 70
Addo, I think the DS was always drums... it was the CX that introduced the Disks to the rears, then the GS then the BX, then the XM, then the Xantia.. in that introduction order
(Note: SM excluded, apart from the looks and the engines I do NOT know near enough about those machines)
Paul
A very sad...
1994 XM 2.1 d auto
