Anyone know where i can get hold of a 1/4 BSP connector to 4.5mm connection for my pressure tester?
I have everything but its been on hold for months as i need this connector!
Cheers
Dave
hydraulic connector?
- x 4
(95) XM Silver 2.1td Exclusive.
(87) Cx 2.5 DTR T1 undergoing major cosmetic surgery.
GPZ500s
GPZ500s
Any good hydraulic specialist should be able to make that. I would mention Pirtek only they can be silly expensive. If you have an industrial estate with an hydraulic service shop I would try them. . Duncan Rodgers may have a place near you and may be worth a try for lots of fittings. Hydrasun is another supplier.
Richard : can you explain what you mean by using Injector pipe?
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
The 1/4 BSP is no problem , as long as u specify male or female , but what do u exactly mean by 4.5MM ?
Now using '00 Xantia LX HDI, pov spec
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident
'99 Xantia HDI 110 Exclusive, RIP
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped )
& a couple of Peugeots !
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
- Xaccers
- x 184
4.5mm hydraulic nut size, to enable fitting the pressur guage to the hydraulic system I would imagineHDI wrote:The 1/4 BSP is no problem , as long as u specify male or female , but what do u exactly mean by 4.5MM ?
DIY sphere tool
DIY sphere tool
- x 4
So is that a piece of 4.5mm tube projecting from the regulator , or , do u mean there is a female thread in regulator that takes a male threaded pipe nut ?
If it is the latter , u do not need to be concerned with the 4.5MM aspect , in fact I can tell u almost for sure that won't be available as it is a Citroen special. What u need to know is what size the thread in the regulator is.
I'm pretty sure it's 10 x 1 MM. So You need a 1/4 BSP male or female to suit your gauge to a 10 x 1 male. That may be available as a single adaptor but it may have to be made up from 2 to handle the step in sizes.
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
In the Citroen hydraulic test kit it is part no. P455-21.
It consists of a rubber pipe about 400mm long with swaged female unions at each end. One end is threaded to take 4.5mm Citroen pipe with rubber seal.
The other end has 1/4 in pipe thread for the pressure gauge.
There is also a 4.5mm male to 3.5mm male converter pipe in the kit.
This looks to be made by brazing the two pipe ends into a short length of slightly larger diameter pipe.
To make up a temporary pipe before I aquired the kit I picked an airline fitting threaded 1/4in one end to suit the gauge and a long spigot for airline hose the other end. The hole in this spigot accepted a good length of the 4.5mm pipe with an ideal clearance for silver soldering. Brazing would have been better but the solder held fine.
John
John
Xmexclusive
