Xantia 2.0 HDI Heater problem
lionstar
Unread post by lionstar »
Hi, My 2.0 HDI heater has just stopped heating the car!.
I have checked the water level, checked fuses. The fan now runs at one speed only! Air con light does not come on either?
Any ideas?
thanks for looking
Clogzz
x 40
Unread post by Clogzz »
Welcome to our playpen, lionstar. :)
Does it not heat because the fan isn’t putting out much hot air, or does it put out cold air ?
The one speed, is it fast or slow ?
The HDI is an efficient engine that doesn’t release much heat, so by cold weather it takes quite long to warm up.
lionstar
Hi, thanks for the reply.
The fan runs at i guess mid to fast speed? Only very cold air! even after long run.
Thanks for helping.
Clogzz
x 40
Looks like an unusual climate control ECU fault.
It lives high up in the dash, towards the centre, behind the glove box.
What you can do for now, is to remove the motorised heater flap mechanism, so as to open the flap to let hot air in.
It’s at the very bottom front of the centre console, on the passenger’s side.
Image Image
Image Image
lionstar
Clogzz wrote:Looks like an unusual climate control ECU fault.
Thanks for the reply. I just tested the control with a meter and i guess you are on the button as there is no life there at all!
I will have a go at you remedy and get back to you,
Thanks again
lionstar
Thanks again
Ok, i pulled the centre of the dash/consul apart and don't seem able to find the flap? any ideas?
thanks
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
The motor pictured in the first photo is found just to the left of the centre console above the felt on the underside of the dash, i.e. head in the footwell looking up.
The ECU is located just to the right of the motor shown right up alongside the transmission tunnel, to remove it pull a plastic clip to one side then pull down the ECU.
One important point to note is that the A/C ECU cannot be replaced with one from another Xantia unless the donor is also an HDi or you have a Lexia to re-programme it for operation on a HDi.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
