Is this a fuel water drain? (Xantia 90Hdi)
rmunns
x 9
Unread post by rmunns »
Took off the engine covers for the first time when I changed the oil/filter last week (have covered 1800miles since then!).
I noticed what I suspect is the fuel filter - quite a large unit with what might be a drain (a large knurled plastic knob) coming out of it.
Should I be doing anything with this?
lexi
x 133
Unread post by lexi »
That`s for priming/draining your filter as you have no rubber bulb like the XUD. It is a totally different procedure on the HDI and is done using the electric pump through the ignition switch IIRC.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
