Tube gauge
lexi
x 134
Tube gauge
Unread post by lexi »
The various hydraulic tubes throught the Xantia. They are different DIA. Are they all the same thickness ? What is that thickness?
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Do you mean all the main pipe work??
4mm 6mm and 8mm for LX and SX Non hydractive suspension.... Hydractive as much bigger pipe size, with rubber sections..
Im sure its 4, 6 and 8mm... someone correct/ confirm?
Paul
A very sad...
1994 XM 2.1 d auto
lexi
x 134
I know that there are 3.5mm and 4.5 mm dia on the brake circuit of my V6. Am I correct in assuming that these are strictly speaking, tubes and not pipe.
As in Seamless Hydraulic Tube
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
citroenxm
Fallen Hero
x 70
Tubes, no they ARE pipes, obviously what the french call pipes - Tubes...
Paul
A very sad...
1994 XM 2.1 d auto
lexi
x 134
Pipe is referred to as inside dia. Tube as outside Dia versus wall thickness.
Anyway Paul. When a brake pipe on the Xantia is mentioned at 3.5mm. is it OD?.........If so I need the gauge thickness :lol:
Martin will know all this stuff. I don`t expect him to give us ALL his trade secrets though :lol:
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
citroenxm
Fallen Hero
x 70
Hmmm not sure... could well be outside Dia.. im uncetain. :roll: :oops:
8, 9 12mm UNIONS??? :lol: :lol: :lol: 8) :o
Paul
A very sad...
1994 XM 2.1 d auto
lexi
x 134
Any advances on this from other members?
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Clogzz
x 40
Unread post by Clogzz »
3.5 mm, 4.5 mm and 6.35 mm are inner diameters.
Wall thicknesses … don’t know. :oops:
ellevie
Unread post by ellevie »
Citroen have gone for a fairly unusual outer diameter of 3.5mm for most but not all of the hydraulic pipework. They have also opted for an unusual pipe flaring method which requires a special pipe flaring tool available from Pleiades. The method they use is to create little bulges at the end of the pipes. An example is shown here,
http://www.citroen-restoration.co.uk/ds ... category=5
David
BX19TRS 120K E Reg 1992-2013
BX19TRS auto abs 96k F Reg
BX19TXD 150k K Reg
lexi
x 134
Thanks guys. I`m trying to cut through the mystery here. 3.5MM tube. Od or Id? The flare? It is really a Swage rather than a flare?. I will take a few pipes from a scrapper and have a closer look. Swaging tools are always more expensive.
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
x 94
Unread post by citronut »
3.5mm is the OD not ID of the smaller pipe work on hydraulic citroens,
and in the UK at least a metal tube is usualy referd to as a pipe, and a rubber pipe is usualy referd to as a tube,
so there and up your pipe or is that tube and smoke it TEA HE
regards malcolm
addo
Sara Watson's Stalker
x 95
Unread post by addo »
No way would it be that small. Your wall diameter is probably less than 0.3mm.
Try gauging the end of a tube inside, with drill bits.
ellevie
The inner diameter is about 1.8mm for a 3.5mm sample.
David
BX19TXD 150k K Reg
citroenxm
Fallen Hero
x 70
DONT get mixed up!!
If you look carefully, it seems that there are two sizes of pipe that run to the rear, ine is for suspension feed which I think is the 3.5 pipe, and theres a larger size pipe that feeds the rear brakes... I know this as Ive just repiped an XM with the two sizes.. (I still cannot tell you what the larger size was :oops: )
Paul
A very sad...
1994 XM 2.1 d auto
x 8378
citroenxm wrote:I know this as Ive just repiped an XM with the two sizes.. (I still cannot tell you what the larger size was :oops: )
4.5mm isn't it Paul?
I can confirm later, I'll get my calipers (vernier ones) on a pipe on the scrapper....
