Tube gauge
lexi
- x 134
Tube gauge
The various hydraulic tubes throught the Xantia. They are different DIA. Are they all the same thickness ? What is that thickness?
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
citroenxm
- Fallen Hero
- x 70
Do you mean all the main pipe work??
4mm 6mm and 8mm for LX and SX Non hydractive suspension.... Hydractive as much bigger pipe size, with rubber sections..
Im sure its 4, 6 and 8mm... someone correct/ confirm?
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
lexi
- x 134
I know that there are 3.5mm and 4.5 mm dia on the brake circuit of my V6. Am I correct in assuming that these are strictly speaking, tubes and not pipe.
As in Seamless Hydraulic Tube
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
citroenxm
- Fallen Hero
- x 70
lexi
- x 134
Pipe is referred to as inside dia. Tube as outside Dia versus wall thickness.
Anyway Paul. When a brake pipe on the Xantia is mentioned at 3.5mm. is it OD?.........If so I need the gauge thickness
Martin will know all this stuff. I don`t expect him to give us ALL his trade secrets though
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
citroenxm
- Fallen Hero
- x 70
lexi
- x 134
Clogzz
- x 40
ellevie
Citroen have gone for a fairly unusual outer diameter of 3.5mm for most but not all of the hydraulic pipework. They have also opted for an unusual pipe flaring method which requires a special pipe flaring tool available from Pleiades. The method they use is to create little bulges at the end of the pipes. An example is shown here,
http://www.citroen-restoration.co.uk/ds ... category=5
David
BX19TRS 120K E Reg 1992-2013
BX19TRS auto abs 96k F Reg
BX19TXD 150k K Reg
BX19TXD 150k K Reg
lexi
- x 134
Thanks guys. I`m trying to cut through the mystery here. 3.5MM tube. Od or Id? The flare? It is really a Swage rather than a flare?. I will take a few pipes from a scrapper and have a closer look. Swaging tools are always more expensive.
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
- x 94
addo
- Sara Watson's Stalker
- x 95
ellevie
citroenxm
- Fallen Hero
- x 70
DONT get mixed up!!
If you look carefully, it seems that there are two sizes of pipe that run to the rear, ine is for suspension feed which I think is the 3.5 pipe, and theres a larger size pipe that feeds the rear brakes... I know this as Ive just repiped an XM with the two sizes.. (I still cannot tell you what the larger size was
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 8391
