Alternator swap
pridz
Alternator swap
Unread post by pridz »
Hi all and a very Merry Christmas to everyone connected to the site.I have the opportunity to replace my worn out alternator from my 19 TD sx p reg with one from a a 2.0i 16v[x reg] , what i would like to know is, is the output[70amp] the same,many thanks pridz
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Hi Pridz,
ALSO Check mounting compatabilities, they ARE different depending on which type of tensioner you have!!
Outputs shouldn't be a problem.. although, im unsure of the output on the TD..
Paul
A very sad...
1994 XM 2.1 d auto
VertVega
x 13
Unread post by VertVega »
Mine has a Valeo alternator with output 90A.
If it's possible send us all available numbers on the type plate.
As citroenxm said, fixings differ between models and depends on with or without air condition.
x 1488
It's possible a diesel alternator will have different sized pulley to a petrol one to account for the generally lower revs of the diesel engine....
VertVega
x 13
pridz, if the alternator is still in the scarpyard :)
here's the Valeo identification number from mine --> A13VI101
There are cross reference tables on the internet where you can compare with yours.
The numbers are usually under thick cover of dust :(
(edit: some more compatible Valeos: A13VI102, A13VI232, A13VI233, A13VI262, ...)
Xantidote
x 4
Unread post by Xantidote »
FWIW, my none aircon Xantia has 80 amp Valeo, model A13V187.
As well as checking the mountings are the same, suggest you make sure the terminals & connectors are the same - somewhere I've seen something to suggest there are differences
Martin
1995 Xantia TDLX (deceased :( )
VertVega
x 13
Re: Alternator swap
pridz wrote:... replace my worn out alternator from my 19 TD sx p reg with one from a a 2.0i 16v[x reg] ...
According to the cross reference data available on Wood Auto web pages, one from a 2.0i 16V would not fit your 19 TD :(
They have different mounting.
Check these Wood Auto (UK) alternator data pages:
--> Xantia 2.0i 16V http://www.woodauto.com/Unit.aspx?Man=V ... f=A13VI101
--> Xantia 1.9 d,td http://www.woodauto.com/Unit.aspx?Man=P ... ef=A13VI87
MikeT
x 232
Unread post by MikeT »
I have a spare pulled from a 1.9TD MK1 with aircon but if there were part numbers and ratings, it's long been washed off. All I can see is VALEO.
