Alternator swap
pridz
Alternator swap
Hi all and a very Merry Christmas to everyone connected to the site.I have the opportunity to replace my worn out alternator from my 19 TD sx p reg with one from a a 2.0i 16v[x reg] , what i would like to know is, is the output[70amp] the same,many thanks pridz
citroenxm
- Fallen Hero
- x 70
Hi Pridz,
ALSO Check mounting compatabilities, they ARE different depending on which type of tensioner you have!!
Outputs shouldn't be a problem.. although, im unsure of the output on the TD..
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
VertVega
- x 13
- x 1489
VertVega
- x 13
pridz, if the alternator is still in the scarpyard
here's the Valeo identification number from mine --> A13VI101
There are cross reference tables on the internet where you can compare with yours.
The numbers are usually under thick cover of dust
(edit: some more compatible Valeos: A13VI102, A13VI232, A13VI233, A13VI262, ...)
Xantidote
- x 4
VertVega
- x 13
Re: Alternator swap
According to the cross reference data available on Wood Auto web pages, one from a 2.0i 16V would not fit your 19 TDpridz wrote:... replace my worn out alternator from my 19 TD sx p reg with one from a a 2.0i 16v[x reg] ...
They have different mounting.
Check these Wood Auto (UK) alternator data pages:
--> Xantia 2.0i 16V http://www.woodauto.com/Unit.aspx?Man=V ... f=A13VI101
--> Xantia 1.9 d,td http://www.woodauto.com/Unit.aspx?Man=P ... ef=A13VI87
MikeT
- x 232
