Odd Xantia radiator leak
firstrebel
Unread post by firstrebel »
Recently I got a coolant leak on my 1.9 TD Xantia SX. It seemed to be coming from the lower offside area of the radiator. Not a very accessible area. The rad was new earlier this year. It leaked mostly when warming up and cooling down; didn't seem to leak much when hot.
Today I had time to look at it and I washed the entire area down with water and let it dry. Removing the intercooler pipe gave more vision. As it warmed up I saw coolant start to trickle from the nylon blanking plug that is about one third the way down the offside of the radiator. The plug turns but will not tighten.
I spoke with DickieG who said that a sensor is fitted there on some cars with AC, so getting an old one might be the easiest way to fix this. I might try to stem the flow by wrapping some PTFE tape around the gap between the rad and nylon plug until I find an old one.
Anyone come across this before?
Bob
Robert Isaac
1997 Xantia 1.9TD SX Estate. 152000 miles
1995 Volvo 855 T5 Auto - Chipped. 186000 miles
x 1240
Unread post by Peter.N. »
Hi Bob
No I havn't but I think that wrapping it with PTFE tape is an excellent idea, might even make the thread grip.
addo
Sara Watson's Stalker
x 95
Unread post by addo »
I was recently warned about these threads by a radiator importer. Basically, he said the thread forming (speaking generally; the car in point was a Vectra) in aftermarket radiator tanks could be a bit hit-and-miss.
If it's never going to be used, a brass plug and blue Hylomar should do nicely.
x 94
Unread post by citronut »
the thread in the OE astra rad fan sensor point was just cut into the thin plastic rad body (thin being about an 1/8th of an inch), so if you go to fit a new sensor you have no chance of making it grop the thread,
then an after market rad had a brass insert built into the rad body,
so i dont know about OE being better aty least in this case
regards malcolm
firstrebel
The rad came from GSF.
Bob
Robert Isaac
firstrebel
Went to GSF today and explained the problem. A helpful man looked around but they did not have any blanking plugs. I showed him the nylon plug on the rad and he came up with a 'rad thermo switch' GSF p/n N93476 that should fit. Came to £12.08. A job for tomorrow.
Bob
Robert Isaac
