Recently I got a coolant leak on my 1.9 TD Xantia SX. It seemed to be coming from the lower offside area of the radiator. Not a very accessible area. The rad was new earlier this year. It leaked mostly when warming up and cooling down; didn't seem to leak much when hot.
Today I had time to look at it and I washed the entire area down with water and let it dry. Removing the intercooler pipe gave more vision. As it warmed up I saw coolant start to trickle from the nylon blanking plug that is about one third the way down the offside of the radiator. The plug turns but will not tighten.
I spoke with DickieG who said that a sensor is fitted there on some cars with AC, so getting an old one might be the easiest way to fix this. I might try to stem the flow by wrapping some PTFE tape around the gap between the rad and nylon plug until I find an old one.
Anyone come across this before?
Bob
Odd Xantia radiator leak
firstrebel
Robert Isaac
1997 Xantia 1.9TD SX Estate. 152000 miles
1995 Volvo 855 T5 Auto - Chipped. 186000 miles
- x 1238
addo
- Sara Watson's Stalker
- x 95
- x 94
the thread in the OE astra rad fan sensor point was just cut into the thin plastic rad body (thin being about an 1/8th of an inch), so if you go to fit a new sensor you have no chance of making it grop the thread,
then an after market rad had a brass insert built into the rad body,
so i dont know about OE being better aty least in this case
regards malcolm
regards malcolm
firstrebel
firstrebel
Went to GSF today and explained the problem. A helpful man looked around but they did not have any blanking plugs. I showed him the nylon plug on the rad and he came up with a 'rad thermo switch' GSF p/n N93476 that should fit. Came to £12.08. A job for tomorrow.
Bob
Bob
Robert Isaac
