Back to the garage! - running rough
Neilsouth
Unread post by Neilsouth »
Picked up the car from garage after it's diff , clutch change. Just got near my house and accelerated foot to the floor , car was warmed up well. It wouldn't fire properly like wet plug syndrome. Then it made this bang sound i thought the diff had gone again , but now it wont let me accelerate , keeps stalling. Squeeking coming from the car , popping , engine shaking , miss firing badly.
Got the guy to come out and drive it himself , thus I REFUSE to spend anymore money on it if it's an engine problem. I'll scrap the car probably for the cost of the gearbox rebuild :roll:
cox377
Unread post by cox377 »
What car was it?
CoXen
x 8391
Neil, sorry to hear this :(
Chances are it's nothing more than a pipe hanging off the inlet manifold allowing air in. Very easy to do when doing such a job on a TU engine. Check for loose things generally around the inlet manifold and the problem should soon show itself.
Neilsouth
CitroJim wrote:Neil, sorry to hear this :(
cox377 xsara 1.4 as i said in all my other posts
Thanks CitroJim :(
Checked pipes looked ok , sensors are ok... engine itself was compression checked it's ok. No smoke out the back , it's looking like one of the ignition parts the garage said. Kinda what we expected but i keep saying to myself i refuse to spend anymore money , they've already had £500+ out of me !
HDI
x 7
Unread post by HDI »
Presumably it was running ok when it went into the garage ?
Now using '00 Xantia LX HDI, pov spec :(
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident :(
'99 Xantia HDI 110 Exclusive, RIP :(
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped :( )
& a couple of Peugeots !
Neilsouth
Perfectly engine wise , the guy said he'd driven it around the local area to test the diff/clutch and that it was running well. :roll:
Neilsouth
RESULT!!!!!!!! , Car is back... The ignition pack was busted , got a second hand one and put it all back free of charge. Took the car out for a good blat right upto rev range and it was fine.
Good news atleast , lets hope it lasts
jgra1
(Donor 2021)
x 37
Unread post by jgra1 »
:D :D :D
HDI
x 7
Pleased for u , I know what a relief it must be after all the disappointment and frustration not to say money !!!
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
Neilsouth
Cheers both ! 8)
