Outside Temperature Reading Not Working
chris050
Unread post by chris050 »
Folks
My 2001 C5 2.0HDi has an outside temperature on the main display but it doesn't work. It simply reads as follows: -- (just 2 dashes)
All other readouts work perfectly.
Any ideas anyone?
Regards
x 1056
Unread post by wheeler »
the exterior temp sensor in the n/s door mirror is almost certainly faulty.
chris050
Hi Wheeler
If this is the problem is it an easyfix or it it likely to be expensive? I can live without it but I would much prefer if it was working.
Regards
x 1240
Unread post by Peter.N. »
I think the sensors from Citroen are less than £20.00 but have a look on ebay you may find some cheaper. If its the same as the XM it lives in the bottom of the near side mirror.
