My remote stopped working all of a sudden.
I have read that it might loose its "coding" if activated "repeatedly out of range" and it would then need to be recoded at a dealers shop.
Can it be anything else? (fuese ? etc)
The central locking itself works when activated by the lock.
Xantia X2- central locking Remote
Krede
Xantia 2.0 Hdi , Talbot Matra Murena 2.2(fuel injected
HDI
- x 7
have you checked the battery in the remote key ?
Now using '00 Xantia LX HDI, pov spec
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident
'99 Xantia HDI 110 Exclusive, RIP
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped
& a couple of Peugeots !
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
davetherave
- x 4
citroenxm
- Fallen Hero
- x 70
Cant you also do a "Home Reminder" like on the Xsaras??
If you put the key in the ignition, and switch on the ignition so the warning lights are all on, then press the lock button a few times, would this not make it remember?? I KNOW IT DOES on the Xsara, because I did it not so long ago on one here, a 2000 X plate model..
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Krede
marsalek
- x 19
Re: Xantia X2- central locking Remote
Hi, on my Xantia HDi I had the same symptoms. Firstly I changed the battery in the remote unit and synchronised the codes (ignition on and press a button on the remote - it is described in the user's manual). But with no effect.Krede wrote:My remote stopped working all of a sudden.
Later, on Lexia the Texton unit had to be newly "programmed" to accept the remote sender and this did the trick
Karel
the_weaver
Is it an infra red remote? if so then you can check if the LED is flashing using a digital camera or camcorder. These can pick up infra red light. This would give you a useful go/nogo test. See my reply to another poster here:-
http://www.frenchcarforum.co.uk/forum/v ... hp?t=28337
Paul
Paul
HDI
- x 7
Krede
