Xantia X2- central locking Remote
Krede
Unread post by Krede »
My remote stopped working all of a sudden.
I have read that it might loose its "coding" if activated "repeatedly out of range" and it would then need to be recoded at a dealers shop.
Can it be anything else? (fuese ? etc)
The central locking itself works when activated by the lock.
Xantia 2.0 Hdi , Talbot Matra Murena 2.2(fuel injected ;) )
HDI
x 7
Unread post by HDI »
have you checked the battery in the remote key ?
Now using '00 Xantia LX HDI, pov spec :(
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident :(
'99 Xantia HDI 110 Exclusive, RIP :(
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped :( )
& a couple of Peugeots !
davetherave
x 4
Unread post by davetherave »
If you replace the battery make sure its a quick swap, as i think mine los its coding because i took the battery out for a while before i found a replacement!
(95) XM Silver 2.1td Exclusive.
(87) Cx 2.5 DTR T1 undergoing major cosmetic surgery.
GPZ500s
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Cant you also do a "Home Reminder" like on the Xsaras??
If you put the key in the ignition, and switch on the ignition so the warning lights are all on, then press the lock button a few times, would this not make it remember?? I KNOW IT DOES on the Xsara, because I did it not so long ago on one here, a 2000 X plate model..
Paul
A very sad...
1994 XM 2.1 d auto
Krede
I have read that about the Xara too... the pug 405 is supposed to be in the same way... tried it a couple of times on my Xantia but to no avail. (and replaced the battery too)
marsalek
x 19
Re: Xantia X2- central locking Remote
Unread post by marsalek »
Krede wrote:My remote stopped working all of a sudden.
Hi, on my Xantia HDi I had the same symptoms. Firstly I changed the battery in the remote unit and synchronised the codes (ignition on and press a button on the remote - it is described in the user's manual). But with no effect.
Later, on Lexia the Texton unit had to be newly "programmed" to accept the remote sender and this did the trick :-) Have heard, that it is a quite common trouble on Xantias Mk2.
Karel
the_weaver
Unread post by the_weaver »
Is it an infra red remote? if so then you can check if the LED is flashing using a digital camera or camcorder. These can pick up infra red light. This would give you a useful go/nogo test. See my reply to another poster here:-
http://www.frenchcarforum.co.uk/forum/v ... hp?t=28337
Paul
HDI
x 7
Xantia 2 is RF type.
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
Krede
Guess I'll have to visit a dea£er then...:(
