Heater/demister fan
koppite34
Heater/demister fan
Unread post by koppite34 »
The fan you control for heating and demister etc wont come on sometimes it does but most of the time it is not and coming up to winter those misty windows will be back but no blower to get rid!.....Is it the relay switch? what to do and cost please!!! Oh its a 1999 xantia
x 8391
Check the connections on the blower assembly, especiaslly the big red and grey ones, both on the 4 way plug and the two singl plugs that connect to the motor. The fan can consume up to 30A on full and the connectors are known to run hot, loose their temper and fail to make a good contact.
The motor brushes could also be worn. Check by looking for voltage at the motor connectors. If you find volts there, the brushes have had it.
If so, source a replacement motor from a scrap vehicle as provide they're from an aircon car, they're all the same.
koppite34
Fan
thanks for that what do i look for when i open the bonnet so i can see what to look for? thanks for that.
x 8391
Re: Fan
koppite34 wrote:thanks for that what do i look for when i open the bonnet so i can see what to look for? thanks for that.
Don't open the bonnet! Instead get your head down in the passenger footwell and undo the five or so Torx screws that hold the fabric trim on under the glovebox. Under her you'll find the blower motor assembly, the pollen filter and the connectors/cables I referred to earlier...
HDI
x 7
Unread post by HDI »
The blower fan is above the passenger footwell beneath a trim cover attached with 2 torx head screws and 5 or 6 plastic allen head trim screws.
Now using '00 Xantia LX HDI, pov spec :(
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident :(
'99 Xantia HDI 110 Exclusive, RIP :(
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped :( )
& a couple of Peugeots !
HDI
x 7
u beat me to that !! #-o
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
x 8391
HDI wrote:u beat me to that !! #-o
Happens a lot around here :lol: :lol: :lol: I had the reverse happen just a few moments ago with John Plum's balljoint thread.
Still better two replies saying much the same than none at all!!!
koppite34
thanks
Thanks to your replies....good job got people who are in the know unlike me eh..lol Thanks i will let you know how i go......pray for me.lol
