Xantia V6 Header Tank
f00lzz
Unread post by f00lzz »
Thought you might like to see thes pic's
http://i69.photobucket.com/albums/i65/z ... 050989.jpg
http://i69.photobucket.com/albums/i65/z ... 050992.jpg
http://i69.photobucket.com/albums/i65/z ... 050990.jpg
http://i69.photobucket.com/albums/i65/z ... 050993.jpg
The day before a trip to Cornwall... typical!
New tank on order 8th October - Brilliant start
Strangely the coolant level light didn't come on... I just happened to notice a slight rise in coolant temp.
The stub which broke off was suprisingly fragile.. will be more careful next time.
Damage to wiring was contained to outer sheath fortunately.
Ian
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
2001 Xantia 3.0 Exclusive
1999 Xantia 1.9TD
1997 Xantia 3.0 Exclusive
1995 XM 3.0 Exclusive Estate
Sid_the_Squid
Unread post by Sid_the_Squid »
Out of interest what did the header tank cost you, I think mine is starting to leak in the middle also.
Gone to the dark side.
Past Citroens
'99 Xantia HDi Exclusive
'99 Xantia 3.0 V6 Exclusive (Green Goblin)
'02 C5 Hdi 110 LX Estate
'98 Xantia 1.8 sx auto with LPG
'00 Xantia Hdi (110) forte
'97 Xantia 1.9D sx
'93 Xantia 1.9D lx (my first) R.I.P
f00lzz
OK make sure you are sitting down..
£64.12 inc vat
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
Clogzz
x 40
Unread post by Clogzz »
Apart from faulty tanks, is that caused by pressure ?
My car runs with the header tank cap loose at the first stop, with no pressure or overflow.
Glycol doesn’t simmer or evaporate.
f00lzz
To be fair I have had a leak on it for months.. just decided to finally let go the day before my hols, I've also bought a radiator for it £250.0
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
Sid_the_Squid
£64.12 inc vat
Wonder if there is a way to repair the tanks? Araldite perhaps?
Past Citroens
'97 Xantia 1.9D sx
f00lzz
Apparently plastic welding is more likely to work, it depends on the quality of the weld... it has to withstand quite a lot of expansion and contraction.
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
x 8401
Sorry to hear that Ian, timing was a bit wasn't it :twisted:
It's a good point about the pressure. Check your cap is good as I've had one (on my own V6) that would not regulate pressure and caused a dangerous tank-splitting pressure to build. Luckily I'd not fully tightened the hose that goes from the transmission cooler to the rad and that gave first.
As you say Clogzz, no real need to keep one's cooling system pressurised at all unless you live at high altitude and even though we think the Peak District is high, it's only high by Blighty standards..
£250 was dear for a rad. I bought mine for £170 after an intensive Google search. When it turned up it was of Spanish origin and claiming to be for a Xantia 2.1TD Auto :roll:
citrov6
Unread post by citrov6 »
when mine went i tried to seal the edge with silicon tape, it didn't work though the pressure was too much and i got a new tank instead. but i think your idea of plastic welding would be your best bet
Love my black v6 xant - only one with cream coloured leather too!
x 1460
Unread post by xantia_v6 »
The plastic is of a type that does not really bond to any adhesive (I tried several).
My plan for next time is to neatly slice the tank around the seam, cut a gasket to go between the halves and then fasten it back together with lots of spring clips of the sort sometimes used to bind papers together.
I know there is a lot of pressure, but if distributed between 20 or 30 clips, I think it should hold.
f00lzz
CitroJim wrote: It's a good point about the pressure. Check your cap is good as I've had one (on my own V6) that would not regulate pressure and caused a dangerous tank-splitting pressure to build. Luckily I'd not fully tightened the hose that goes from the transmission cooler to the rad and that gave first.
Ok new cap it is then.. It was the best price at short notice, I had a quote of over £300 from one place!
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
andmcit
x 30
Unread post by andmcit »
My pal has just purchased a v6 where the header had split in two along the
moulding line on the midway waistline and the previous eller has glued and
then bolted the halves back together again around the wide collar at regular
15mm intervals. I say glue but it may even be resin and whilst it doesn't really
look pretty it seems to be holding up well having already covered 250 miles
in it's new ownership.
I regret not bidding for the buy it now £49 rad on ebay a few months back
that specifically only listed the v6 24v Xant - anyone here the fortunate bidder!?
Andrew
x 8401
andmcit wrote: I regret not bidding for the buy it now £49 rad on ebay a few months back
I only saw it after I'd already ordered my new one :twisted: :twisted: :twisted:
xmexclusive
Unread post by xmexclusive »
Standard plumbing ABS cement can often repair many of Citroens plastic items. Spanish radiators are usually bad news in Citroen cars.
John
Xmexclusive
x 8401
xmexclusive wrote:Spanish radiators are usually bad news in Citroen cars.
:cry: :cry: In what way John?
