Adjusting a 205 GLD Clutch
maxfox44
Unread post by maxfox44 »
How do I adjust the clutch. I've just replace the release arm after it snapped. Now the clutch pedal is right above the brake.
Thanks in advance
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
Measure the travel from highest point to the floor. It should be 130 to 150mm. If it's out, undo the lock nut at the gearbox end of the cable, then turn the adjustment nut backwards/forwards until the measurement at the pedal is correct. The clutch pedal will always be higher than the brake. Before measuring, press the pedal down several times.
maxfox44
which way do you turn it?
JohnD
(Donor 2022)
x 72
Unscrew will lower the pedal, tightening will raise it - as far as I remember - it's a long time since I did one!
maxfox44
Thought as much. I think the clutch is almost knackered, so it will be a trade off between a slightly high pedal and a working clutch.
Wish me luck. Thanks
maxfox44
I've managed to adjust the clutch to a reasonable level. However, now there is a noise during clutch in and around the bite point. Does this mean its finally knackered? The noise goes after a few changes.
Any ideas, I don't want to change the clutch, as the car is going to the car dealer in the sky very soon
