2.0 Turbo Exhaust Manifold Plate Location?
steelcityuk
Unread post by steelcityuk »
Hi All.
This is a duplicate of a question posted on the XM forum, I'm hoping for a quick answer hence the duplicate posting.
I hope you all don't mind?
Here's a question for all TCT fans.
On mine there was a stainless steel 'plate' that fitted between the cylinder head and the exhaust manifold. Now I assume that it fits after the gaskets - so it goes cylinder head then gasket then plate then manifold. And that it's arranged so it's 'edge' faces away from the engine. But I can't find it on the Citroen parts list or in the Haynes.
Are my assumptions correct? I ask because it shows signs of previous leakage.
Thanks.
Steve.
not applicable
steelcityuk
In the end I had to go with a hunch that is part of the heatshield setup. And that the edge/flange points away from the engine.
Steve.
not applicable
x 8391
Steve,
I cannot recall seeing this on a Xantia TCT.
I'm away at the mo but I'll have a gander in Laser when I get home and see what that says.
XantiaMan
x 18
Unread post by XantiaMan »
Mine does have a heat shield which i suspect is part of the exhaust manifold gasket.
2020 Peugeot Partner
2017 Fiesta ST
2001 Ford Puma 1.7 VCT
2006 Ford Fiesta Zetec
http://www.facebook.com/kidmans" onclick="window.open(this.href);return false;
steelcityuk
Here's how it looks in position.
I assume the idea is to contain the heat from the turbo as much as possible and let the cooling system deal with it.
Steve.
not applicable
