Hi All.
This is a duplicate of a question posted on the XM forum, I'm hoping for a quick answer hence the duplicate posting.
I hope you all don't mind?
Here's a question for all TCT fans.
On mine there was a stainless steel 'plate' that fitted between the cylinder head and the exhaust manifold. Now I assume that it fits after the gaskets - so it goes cylinder head then gasket then plate then manifold. And that it's arranged so it's 'edge' faces away from the engine. But I can't find it on the Citroen parts list or in the Haynes.
Are my assumptions correct? I ask because it shows signs of previous leakage.
Thanks.
Steve.
2.0 Turbo Exhaust Manifold Plate Location?
steelcityuk
not applicable
steelcityuk
- x 8088
XantiaMan
- x 18
Mine does have a heat shield which i suspect is part of the exhaust manifold gasket.
2020 Peugeot Partner
2017 Fiesta ST
2001 Ford Puma 1.7 VCT
2006 Ford Fiesta Zetec
2017 Fiesta ST
steelcityuk
