C5 - Multifunction Display
fred1
Unread post by fred1 »
Since I changed the bulbs on the MF display on my 2001/2 C5 2.2 HDI Excl I have been unable to get the left hand button to access the reset menu for date/time etc.
When I press the button the screen goes dark and nothing happens.
When released, the date/time is flashing and counting up from when battery reconnected.
All the other functions and alerts are working ok.
Anyone any ideas ?
Anyone know if you can fit a used replacement from the scrappy or are they coded to the car ?
John
x 1056
Unread post by wheeler »
If i remember right the only programming in them is if the car has a CD changer or not. So as long as yours doesent have on then no programming needed.
x 1942
Unread post by Paul-R »
In such a case I would take the unit out and check the connection to the wiring loom. I would pull the plug out and push it in a few times.
fred1
Thanks guys,
Tried reseating the connector and checked cable etc (with battery disconnected) but no joy!
Regards
John
x 1942
It sounds like you may have damaged the unit when replacing the bulbs. I've not heard of this happening before but there's always a first time!
Scrapyard? The same unit is fitted to some Xsaras (and possibly other models) so they shouldn't be difficult to find.
uncle buck
x 10
Unread post by uncle buck »
Either of these the correct part....
>> Part 1 <<
>> Part 2 <<
I have bought from this seller before & can recommend them.
Cheers.
2006 C4 1.6 HDi 16V (92) non FAP
2001 Xsara II 1.4 LX
2001 Renault Laguna II 1.9dCi Sport Tourer
x 1942
Even if your car had the first type of display I would fit the second type as it shows more information (which door is open, outside air temp all the time).
In fact I did this very upgrade a few months ago on the Xsara (an LX). I found 2 examples in a scrappy, one in a Xsara SX and the other in a C5.
