C5 Instruument Cluster Removal?
altosax-123
how do you remove the speedo cluster from a 2003 C5
- x 1055
It's very easy. Adjust the steering column fully out & downward then if you look at the bottom of the surroud of the instrument panel you will see 2 dots on the plastic, you need to use some plastic levers or similar at these points & you just carefully lever the paney slowly & evenly upwards & the panel just pops out. It just pushes back in aswell. There are no screws fitted.
- x 8420
KevMayer
