C5 Instruument Cluster Removal?
altosax-123
Unread post by altosax-123 »
how do you remove the speedo cluster from a 2003 C5
x 1056
Unread post by wheeler »
It's very easy. Adjust the steering column fully out & downward then if you look at the bottom of the surroud of the instrument panel you will see 2 dots on the plastic, you need to use some plastic levers or similar at these points & you just carefully lever the paney slowly & evenly upwards & the panel just pops out. It just pushes back in aswell. There are no screws fitted.
x 8422
Post title edited to be relevant to content and to help searches in the future :)
KevMayer
Unread post by KevMayer »
I use the handles of 2 dessert spoons.
Cheers, Kev
