How much to buy and fit a new steering rack
KP
x 27
Unread post by KP »
On ebay near Gretna 160344310465
Could it just be some hydraulic pipe that has come loose or split?
With mileage like that it should definately be on someones saving list(cough cough Jim looking for new project now, cough cough ;-) )
I would have it for myself if it weren't 3 hours away as i need a lot of spares for my activa or would possibly fix it up and sell it on :)
x 8444
More than likely the pinion valve.
Mr. Pleiades will recondition one of those.
Or else the ram and they're readily available.
citroen7
Unread post by citroen7 »
if it was not for a certain stretch of water i would have that on my drive tomorow i wonder hoe bad the leak is? would it drive on to a transporter as £200 would get it to my door :D
Sl4yer
Unread post by Sl4yer »
citroen7 wrote:if it was not for a certain stretch of water i would have that on my drive tomorow i wonder hoe bad the leak is? would it drive on to a transporter as £200 would get it to my door :D
I'm sure it would if you filled it with green blood first. Looks to be sitting comfortably enough.
Now Citroenless for the first time in 20 years
2008 Mazda RX-8 231
2007 Honda CR-V Auto
KP
x 27
Unread post by KP »
Seller says its also a constant drip, not a stream or the like so would easy make it up onto a transporter or loader i would imagine if not drive short distances between checking the fluid if you had to chance it.
