Series 2 in to 1 Air Con
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Hi all...
A question for you, does any one know if the Air Con evaporator (Behind the Dash) from a S2 car fit a S1 car?? I KNOW I need to loose some of the glove box space, but will the actuall unit fit behind the S1 dash??
Hmmm, I wonder actually, if the S2 dash would fit the S1 car... :!:
Paul
A very sad...
1994 XM 2.1 d auto
citroenxm
Fallen Hero
x 70
Well, if anyone thinks im MAD, well maybee I am.. Ive got the dash out of the S2 donar, need to see now, but it looks like the heater unit is MUCH easyer to remove in the Xantia - unlike the XM it doesn't have the harness running across it.
The Blower / exchanger side splits from the heater side, so the whole lot doesn't need to come out..
P
A very sad...
1994 XM 2.1 d auto
citroenxm
Fallen Hero
x 70
Well, incase any one MIGHT be wondering, yes the system DOES swap over, and from the looks of it, this is one area of S1 and S2 that NEVER changed!!
Got the evaporator in this weekend, HOWEVER, of course, the wireing is all different, and Im gonna have to setup a manual wireing loom to switch the compressor on/off, via the pressure switch, useing the evaporator temperture probe...
All mad stuff! Gota few engine maods to do now for the compressor to go on...
Paul
A very sad...
1994 XM 2.1 d auto
x 8412
Paul,
If you need any wiring diagrams, let me know...
citroenxm
Fallen Hero
x 70
:D :D :D :D :D :D
THANKS JIM! Love one!
As per wanted post, do you also have a roller for the auto tensioner from a 1997/98 XUD?? You know, the ones that split the aux belts??
Paul
A very sad...
1994 XM 2.1 d auto
x 8412
No worries Paul, I'll post up the diagrams later...
citroenxm wrote: As per wanted post, do you also have a roller for the auto tensioner from a 1997/98 XUD??
Yes!!! I always knew my magpie/squirrel tendencies would come in useful one day. I only throw anything away when it really is useless!
I'm almost virtually 100% certain I have one.
Will let you know when I'm home and looked in my squirrel box.
citroenxm
Fallen Hero
x 70
FANTASTIC!
I have the mounting bracket, and the alloy sump, so I need to move the HP pump to the top and swap oil sumps..
Pushing it a bit, but I may need the torx bolt, unless any other sort will do.. Im ok for the ecentric roller, found a spare one the other week, befor realising I needed it.. I have seen it recently too.... :?
What sort of beer tokens would you like?
Paul
A very sad...
1994 XM 2.1 d auto
x 8412
Paul, I have the roller you need. FOC.
PM me your name and address and it'll be shortly in the post :wink:
I'll post the diagrams a bit later. Got to set the scanner up but dinner soon calls :wink:
x 8412
Hi Paul,
The pulley will be in the post this afternoon...
Here is the circuit of the Late Mk1 Aircon system
And here is the circuit of the Early Mk2 Aircon System
citroenxm
Fallen Hero
x 70
THANKS EVER SO MUCH JIM! Yur an absolute star!!!
Incidentally, I didn't realise your V6 was a Maritious Blue one!
Ive also got a Maritious Blue V6 to collect, but mines earlyer then yours on a P plate, 1997!
Its up in Scotland, and hoping to go get her VERY soon.. She DOES need 3 ABS sesnors though..
Best regards
Paul
A very sad...
1994 XM 2.1 d auto
x 8412
No worries at all Paul :D
Great stuff on the soon to be acquired V6 :D :D That must be one of the first then and in a really lovely colour too!
citroenxm wrote: She DOES need 3 ABS sesnors though..
On a V6, that's getting off lightly :lol: I wish mine only needed 3 ABS sensors :twisted: Mind you, it's already consumed one..
Looking forward to lots more news on it :wink:
citroenxm
Fallen Hero
x 70
No problems, jim, Ill fill you in..
I know she DOES need a passenger side wing to make PERFECT! and a bumper as shes had a small bump, but managed to sort her JUST for mot...
Paul
A very sad...
1994 XM 2.1 d auto
citroenxm
Fallen Hero
x 70
Jim,
Sent you a personal EMAIL with a couple of pics, the pully doesn't fit.. I think theres a difference between the metal arrangement and plastic pull arrangement...
Rgds
Paul
A very sad...
1994 XM 2.1 d auto
x 8412
Hi Paul,
Sorry for the delay :oops: I've just seen your email as I've only been looking at the forum from a remote location with no email access for a couple of days :twisted:
Indeed they are different :shock: There's a shoulder on the plastic pulleyed one that is not present on the all-metal one.
I've just looked at the remains of the old tensioner the pulley came from and wondered if you could prehaps transfer the needle rollers from one to the other but you'd need a press as the cages are tightly in there and what's the betting the needle roller cages are different sizes :twisted:
In mine the needle rollers and the bearing sleeve are well worn and not up to any further use.
I'm really sorry Paul that this has all ended up not resolving your needs :(
citroenxm
Fallen Hero
x 70
Its the SAME as the HDi pully... Do you know or have a HDi pully then??
Plastic it will have to be
Rgds
PAul
A very sad...
1994 XM 2.1 d auto
