Front brake hoses
Stempy
Front brake hoses
Unread post by Stempy »
Can anyone confirm that GSF part N65717 is the correct length front brake hose for a Xant V6? I'm currently overhauling the whole brake system and while the hoses look ok, for the sake of an extra £8 a side I thought I may as well replace them while I'm in there.
Lexia ponce
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
V6's, HDi's etc which have the largest calipers have a longer brake hose of 370mm length compared with 355 for the rest so check the length.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
SLYTZD
Goodridge Hoses - Stainless Steel - Xantia
Unread post by SLYTZD »
Found these the other day, not sure if they would fit a V6 but they might be able to find some that do.
http://www.motorsportworld.co.uk/framef ... PID=233131
Simon
'96 Xantia Activa in Silver 95,000
Stempy
Ah right, so there are only two different lengths, so buy the longest one :) As an aside, I note that the calipers are manufactured by Bendix, although it's often mentioned that the V6's were fitted with Bosch calipers :? Or are they the same thing :?:
Lexia ponce
Stempy
Re: Goodridge Hoses - Stainless Steel - Xantia
SLYTZD wrote:Found these the other day, not sure if they would fit a V6 but they might be able to find some that do.
Mmmm very tarty, braided steel hoses. Pity no one would see them :roll: Dunno if it's worth the extra cost though. I'd be worried also about LHM compatibility, I've seen what it does to hose that's not actually designed for it.
Lexia ponce
addo
Sara Watson's Stalker
x 95
Unread post by addo »
The "proper" braided sheath hoses are lined with either 30 or 40 thou wall thickness Teflon. Neither fluid type will touch it. However, the relative fragility of a Teflon liner vs rubberlike synth polymers is why it's so critical not to stretch or kink them.
Mmmm very tarty
I laughed at this. For someone (me) espousing their endlessly "immature" behaviour I actually dislike lifting the bonnet or showing off the underpinnings of a car, more than is actually needed...
Regards, Adam.
Stempy
Well I replaced the hoses with standard fitment items from GSF and I'm glad I did because when removed i discovered they are very perished up at the bulkhead end, though this is very hard to see in situ with the spring sheath in the way. The caliper end looks fine so a bit deceptive. I guess they've given good service though at 10 years old and 108k miles.
Lexia ponce
John Plum
x 5
Unread post by John Plum »
GSF part N65717 is the part for my car, and measures 400mm (confirmed by GSF).
John Plum
Xantia II Estate,1999, 2.0 HDI LX, 17000 miles, manual
