c5 total loss of power
mm1
Unread post by mm1 »
have had months of trouble free driving,touch wood.last week the clutch went.got it done to the tune of 900euro. :shock: the morning after i got the car done,i went to take off and the car was as dead as could be.it cured itself after a few minutes.parked the car for a few hours and the same thing happened.it seems to happen if the car is parked for any period of time.its a c5 hdi 110.any ideas?
x 94
Unread post by citronut »
mm1 wrote
i dont kow what your fault is appart from maybe a bad conection ,
"i got the car done"
but it sounds like the car was not the only one done, as that price sounds very steep
regards malcolm
mm1
i thought that the 900 that i was quoted was better than the 1200 that the main dealer was.the clutch kit was 180 and a dual flywheel that 420 and labour after that.have been back to the mechanic and he says its an air flow meter,is this an expensive part?
x 5672
If he means the MAF then they are approximately £100.
You could try cleaning it with carburettor cleaner, it's easy enough*. Just don't touch it or drop it.
If it needs replacing be sure that a genuine Citroen component is used.
*I did mine last week. No improvement unfortunately :cry:
Xantidote
x 4
Unread post by Xantidote »
It wouldn't be as simple as the battery earth? Friend of mine had gearbox replaced on an old Peugot 405, and then had starting problems . Turned out they'd not done proper job of ensuring a good earth when refixing earth cable back on to the body.
Good luck whatever the problem - Martin
Martin
1995 Xantia TDLX (deceased :( )
