Does anyone know if its still possible to get hold of the stainless steel replacements for the bumper and side strip brightwork on a Xantia Mk1?
I'm sure I remember these being advertised a few years back.
Thanks,
WAINY.
Replacement Xantia "chrome" inserts
wainy
WAINY
2016 C4 Picasso Exclusive (Black)
1983 GSA X1 (Black - being restored)
Ross_K
- x 110
MikeT
- x 232
- x 94
davetherave
- x 4
ACTIVE8
- x 6
Same here it seems to be a Citroen design feature.davetherave wrote:Ill have to add these to the ever increasing list of stuff wanted for the xantia as mine are a bit white!
Maybe the amount of milkyness can be related to how old the car is, so like tree rings the age can be determined from it.
Could we be in for the same problem with the newer cars C4 C5 etc also, as they are also probably made cheaply unlike a CX I saw recently, which had original trims in good condition, and the part looked better made, and therefore had lasted longer!
ACTIVA
wainy
Thanks for all the replies to this post. Citronut..... if you do find the number for Brian Primmer that would be great.
By the way, I've found that autoglym bumper care brightens up the strips quite well but obviously can't hide the "crustiness" when they start to degrade.
WAINY.
WAINY.
WAINY
DickieG
- Monaco's youngest playboy
- x 33
ACTIVE8
- x 6
- x 94
davetherave
- x 4
Citroenmad
- x 110
We got a set of them from Brian at Weatherby a few years ago. For the white Xm, they do look far better than the crusty old ones which were pealing off.
Front and rear bumpers are a problem though. New strips are available from Citroen, atleast they were for the Xm, although they are a bit a bit pricey. If i remember rightly i think it was £150 for the pair, front and rear strips for the Xm. Not sure how long they will be available for though.
Oh, on the new ones i put a bit of silicone sealer around the end of the Citroen bumper ones, hopefully that will keep the water from between the plastic and the chrome effect for a little longer.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
