Battery probs
vince
- x 13
ACTIVE8
- x 6
Re: Battery probs
Do you mean the positive terminal clamp?superloopy1 wrote:Hi
For a while now my Activa's battery has run moreorless flat when left standing from one weekend to another.
I'm assuming this is not normal. The battery is an almost new Citroen one boughtby previous owner so i can draw the conclusion that he also had the same problem![]()
I've just removed the battery today for yet another charge and noticed that the positive terminal is beginning to split. Could this be the cause of my problems?
Or unlikely, given that there IS some '+' contact there.
Charger confirms that battery is flat.
Any ideas, removal of boot bulbs etc.
Electrovalves are sometimes a problem i've read but in this case i can hear them clicking in/out ok.
ACTIVA
Sl4yer
- x 5671
Have you a multimeter there that you can use to test for any residual drain when everything is off?
It has been mentioned somewhere that the alarm system developes a fault that drains the battery.
If it has been allowed to go flat a few times the plates may have buckled and come into contact with one another that will reduce the charge that the battery can hold. Best to get it tested and eliminate that first.
DickieG
- Monaco's youngest playboy
- x 33
JamesQB
- x 5
I'd connect an ammeter in series with the positive lead to the battery post and get a reading with ignition off to see what the drain is. Then I'd remove the fuse the last post mentioned for the alarm and see if the drain reduces significantly.
If you don't have a meter, another option is to put a low wattage 12V bulb in series with the battery lead and see how brightly it lights with everything off. See how much it dims when you removed the fuse mentioned before.
Honda Civic 2.2 CDTi 2006
Peugeot 407 2.0 HDi 2007
- x 1240
I have an XM estate which only gets used on Sunday - to take the dustbins down to the farm. I leave it running for five or ten minutes which should be more than long enough to put back what starting took, but the battery gets weaker by the week, until I charge it. I have now taken to disconnecting it every time, just take the + lead off, and its as fresh as a daisy every time I start it. I think its the alarm that's draining it. If its in daily use, no problem.
Deanxm
- x 87
I was having the same problem a while ago on the XM, the trouble was not a power drain as such, i only use the car at weekends too and it would not start or it would struggle to start come saturday, turned out it was not the 7 year old cit battery that was to blame or the new battery i replaced it with
but in my case the battery terminals where tight and clean but the negative wires were loose inside the moulded lead (nothing you could feel) terminal itself causing it not to charge properly, £5 at halfords for new terminals sorted it all out
It would wind over quick enough with a fresh battery on it or when warm but not after a week under the car cover, twice it started at home then after a 5 min drive to tesco's when swmbo came back out with a trolley of frozen food it would rufuse to do so again (which didnt get me or the car into her good books
Worth a look if you have the moulded lead clamps
Good luck
D
Good luck
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
Deanxm
- x 87
wouldnt use an isolator, the ecu is the adaptive type and if you cut its power it will have to relearn its finetune settings everytime you take the car out again, not to mention having to reset the clock, radio etc etc it will get rather wearing having to do that every week.
D
D
XM Prestige PRV6 92
- x 1240
DickieG
- x 33
To use the ammeter disconnect the battery positive lead then connect one wire from the ammeter to the battery, the other to the battery lead (don't turn on the ignition as you'll fry the ammeter) and observe the current flow. Remove each fuse in turn, when removing one particular fuse causes a significant change in current flow you have found the source of the leak.superloopy1 wrote:I'll then do the ammeter bit (i've got an ammeter but absolutely no idea how to use it?) and see what happens followed by DickieG's removal of fuse 17 to the alarm BUT i've not had the car alarmed for the past week so not too sure about this one.
In the case of the alarm on Bob's car the alarm wasn't set.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
Deanxm
- x 87
DickieG
- x 33
Peter.N. wrote:Mines got one of those beautiful mechanically injected diesels - so I dont have that problem
Judging by reputation I imagine XM electrics make up for thatDeanxm wrote:Theres always one smug git around isnt there![]()
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
Deanxm
- x 87
Now now, you shouldnt listen to everything you hear, some of my electrics still work
D
D
XM Prestige PRV6 92
- x 8389
Mike,
You might find this Document useful.
It details the current consumption of all the devices that remain live when the ignition is off...
A very good place to look is to check the Hydractive system is puttting the system into hard mode (i.e. electrovales switched off) 30s after all doors are shut. Sometimes a door or boot switch causes the system to remain active and hold the suspension in soft mode, thus draining the battery.
