Battery probs
vince
x 13
Unread post by vince »
ACTIVE8
x 6
Re: Battery probs
Unread post by ACTIVE8 »
superloopy1 wrote:Hi
For a while now my Activa's battery has run moreorless flat when left standing from one weekend to another.
I'm assuming this is not normal. The battery is an almost new Citroen one boughtby previous owner so i can draw the conclusion that he also had the same problem :?
I've just removed the battery today for yet another charge and noticed that the positive terminal is beginning to split. Could this be the cause of my problems?
Or unlikely, given that there IS some '+' contact there.
Charger confirms that battery is flat.
Any ideas, removal of boot bulbs etc.
Electrovalves are sometimes a problem i've read but in this case i can hear them clicking in/out ok.
Do you mean the positive terminal clamp?
ACTIVA
Sl4yer
Unread post by Sl4yer »
The boot light is often a good place to start!
Check the voltage with the engine running. It is actually charging?
Now Citroenless for the first time in 20 years
2008 Mazda RX-8 231
2007 Honda CR-V Auto
x 5674
Have you a multimeter there that you can use to test for any residual drain when everything is off?
It has been mentioned somewhere that the alarm system developes a fault that drains the battery.
If it has been allowed to go flat a few times the plates may have buckled and come into contact with one another that will reduce the charge that the battery can hold. Best to get it tested and eliminate that first.
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
My mate Bob (Firstrebel) came across this very problem recently, removing fuse 17 (alarm) stopped the excess battery drain.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
JamesQB
x 5
Unread post by JamesQB »
I'd connect an ammeter in series with the positive lead to the battery post and get a reading with ignition off to see what the drain is. Then I'd remove the fuse the last post mentioned for the alarm and see if the drain reduces significantly.
If you don't have a meter, another option is to put a low wattage 12V bulb in series with the battery lead and see how brightly it lights with everything off. See how much it dims when you removed the fuse mentioned before.
Honda Civic 2.2 CDTi 2006
Peugeot 407 2.0 HDi 2007
x 1240
Unread post by Peter.N. »
I have an XM estate which only gets used on Sunday - to take the dustbins down to the farm. I leave it running for five or ten minutes which should be more than long enough to put back what starting took, but the battery gets weaker by the week, until I charge it. I have now taken to disconnecting it every time, just take the + lead off, and its as fresh as a daisy every time I start it. I think its the alarm that's draining it. If its in daily use, no problem.
Deanxm
x 87
Unread post by Deanxm »
I was having the same problem a while ago on the XM, the trouble was not a power drain as such, i only use the car at weekends too and it would not start or it would struggle to start come saturday, turned out it was not the 7 year old cit battery that was to blame or the new battery i replaced it with :roll: but in my case the battery terminals where tight and clean but the negative wires were loose inside the moulded lead (nothing you could feel) terminal itself causing it not to charge properly, £5 at halfords for new terminals sorted it all out :D
It would wind over quick enough with a fresh battery on it or when warm but not after a week under the car cover, twice it started at home then after a 5 min drive to tesco's when swmbo came back out with a trolley of frozen food it would rufuse to do so again (which didnt get me or the car into her good books :lol:
Worth a look if you have the moulded lead clamps
Good luck
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
Deanxm
x 87
wouldnt use an isolator, the ecu is the adaptive type and if you cut its power it will have to relearn its finetune settings everytime you take the car out again, not to mention having to reset the clock, radio etc etc it will get rather wearing having to do that every week.
D
XM Prestige PRV6 92
x 1240
Mines got one of those beautiful mechanically injected diesels - so I dont have that problem :D
DickieG
x 33
superloopy1 wrote:I'll then do the ammeter bit (i've got an ammeter but absolutely no idea how to use it?) and see what happens followed by DickieG's removal of fuse 17 to the alarm BUT i've not had the car alarmed for the past week so not too sure about this one.
To use the ammeter disconnect the battery positive lead then connect one wire from the ammeter to the battery, the other to the battery lead (don't turn on the ignition as you'll fry the ammeter) and observe the current flow. Remove each fuse in turn, when removing one particular fuse causes a significant change in current flow you have found the source of the leak.
In the case of the alarm on Bob's car the alarm wasn't set.
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
Deanxm
x 87
Hi Peter
Theres always one smug git around isnt there :lol: :lol:
D
XM Prestige PRV6 92
DickieG
x 33
Peter.N. wrote:Mines got one of those beautiful mechanically injected diesels - so I dont have that problem :D
Deanxm wrote:Theres always one smug git around isnt there :lol: :lol:
Judging by reputation I imagine XM electrics make up for that :lol: :lol:
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
Deanxm
x 87
Now now, you shouldnt listen to everything you hear, some of my electrics still work :lol:
D
XM Prestige PRV6 92
x 8422
Mike,
You might find this Document useful.
It details the current consumption of all the devices that remain live when the ignition is off...
A very good place to look is to check the Hydractive system is puttting the system into hard mode (i.e. electrovales switched off) 30s after all doors are shut. Sometimes a door or boot switch causes the system to remain active and hold the suspension in soft mode, thus draining the battery.
