DumpValves
KP
x 27
DumpValves
Unread post by KP »
Does the standard Activa have a re-circulating dump valve fitted as standard does anyone know?
I can see the fittings for it on mine but its been blanked off on it for some reason....
SLYTZD
Unread post by SLYTZD »
Short answer is no it doesn't. Just the holes pluged.
If you do fit a Dump Valve the best place to conect the actuator pipe is on the inlet manifold just underneath.
Simon
'96 Xantia Activa in Silver 95,000
KP
x 27
Unread post by KP »
I wonder why they did not fit one as surely it would help lengthen the life of the turbo sa you wouldn't get 'turbo stall' when you are trying to progress quickly thru the gears and it may shorten the 0-60 time a little bit as well as the turbo will still be spinning??
XantiaMan
x 18
Unread post by XantiaMan »
Think its been discussed before this one. It wont significantly shorten turbo life, because its only running a low amount in the first place. I also think changing gear quick enough without a dump valve gives better response than having the boost escape to atmosphere.
2020 Peugeot Partner
2017 Fiesta ST
2001 Ford Puma 1.7 VCT
2006 Ford Fiesta Zetec
http://www.facebook.com/kidmans" onclick="window.open(this.href);return false;
KP
x 27
Unread post by KP »
I was thinking more of a re-circulating type of dumpvalve, mainly as they can be gotten off many scrapped cars but also that they are much quieter in operation :)
x 8252
KP wrote:I wonder why they did not fit one
Strangely, the Pug 406 Executive (and SRi I believe)that used the same 2.0TCT engine did have a recirc valve fitted...
KP
x 27
Unread post by KP »
hmmm :) spotted one thats being broken on ebay so may ask about the recirc dumpvalve.
Hopefuly i'll have got the fault codes in the hydractive and ARCS ecu's cleared but we will see :)
