I have to scrap my 95 Xantia 1.9 TD SX. It was enjoyable while it lasted. In the meantime I will be driving a 97 Citroen ZX and was wondering if theres any way I can salvage some of the Xantia parts and transfer them to the ZX before the car is taken away. I was thinking primarily of the Xantia radio and speakers [and any other electrical systems which may be compatible]. Any help / knowledge / tips would be most welcome.
Cheers.
Xantia parts in a ZX
- x 94
if you are scrapping the XANT can i ask you to remove all the steering columb wireing, the rotary in between the steering wheel and top of the columb, and as much of the loom from the plug conector inside the columb shroud which the rotary plugs into, from there to the radio, and let me know how much you would like foer it including any carridge
regards malcolm
regards malcolm
red_dwarfers
- x 58
Ross_K
- x 110
Sl4yer
Remove (carefully) and keep the front door lock buttons. I reckon the ZX uses the same ones, and they are no longer available. Apart from that (and the engine and gearbox if both are TDs) I can't think of anything.
Now Citroenless for the first time in 20 years
2008 Mazda RX-8 231
2007 Honda CR-V Auto
AndersDK
- x 1238
