Xantia parts in a ZX
citroencurran
Unread post by citroencurran »
I have to scrap my 95 Xantia 1.9 TD SX. It was enjoyable while it lasted. In the meantime I will be driving a 97 Citroen ZX and was wondering if theres any way I can salvage some of the Xantia parts and transfer them to the ZX before the car is taken away. I was thinking primarily of the Xantia radio and speakers [and any other electrical systems which may be compatible]. Any help / knowledge / tips would be most welcome.
Cheers.
x 94
Unread post by citronut »
if you are scrapping the XANT can i ask you to remove all the steering columb wireing, the rotary in between the steering wheel and top of the columb, and as much of the loom from the plug conector inside the columb shroud which the rotary plugs into, from there to the radio, and let me know how much you would like foer it including any carridge
regards malcolm
red_dwarfers
x 58
Unread post by red_dwarfers »
I wouldn't have thought that the head unit was compatible, is is a DERV ZX you are transferring to? Im sure a lot of the engine parts would come in useful to keep as spares.
Kev
'19 C4 Cactus 130 Flair
Ross_K
x 110
Unread post by Ross_K »
The radio's not compatible.
Well, maybe if you secure it to the dash with some silicone sealant or something.... :lol:
Sl4yer
Unread post by Sl4yer »
Remove (carefully) and keep the front door lock buttons. I reckon the ZX uses the same ones, and they are no longer available. Apart from that (and the engine and gearbox if both are TDs) I can't think of anything.
Now Citroenless for the first time in 20 years
2008 Mazda RX-8 231
2007 Honda CR-V Auto
AndersDK
Unread post by AndersDK »
The heater radiator is the same for Xantia and ZX (& Xsara & Berlingo)
Except its no fun to remove from the Xantia :roll:
Anders (DK) - '90 BX16Image
x 1240
Unread post by Peter.N. »
The engine and gearbox are pretty well the same asuming they are both turbo.
