I am about to change the front discs and pads on my 1600cc petrol xantia.
I am about confused about the procedure for compressing the cylinders to allow for the new pads and also for the handbrake adjustment procedure. All tips gratefully recieved
Changing discs and pads on 1600 xantia
Xaccers
- x 188
Once you've got the old pads out, you'll see that on the piston there's a + cut out of it's face.
Get one of the old pads or a suitable flat rod, and stick it across the face of the piston in two of the notches.
Rotate the piston clockwise to screw it back in.
It takes a while to wind it back all the way.
DIY sphere tool
DIY sphere tool
- x 5672
Aren't they handed Xac, one going clockwise and the other counterclockwise?Xac wrote:Once you've got the old pads out, you'll see that on the piston there's a + cut out of it's face.
rory_perrett
sadie
Thanks for the help Xac, V useful. Still a bit confused re handbrake cable adjustment. Any help gratefully receivedXac wrote:Once you've got the old pads out, you'll see that on the piston there's a + cut out of it's face.
rory_perrett
