Changing discs and pads on 1600 xantia
sadie
Unread post by sadie »
I am about to change the front discs and pads on my 1600cc petrol xantia.
I am about confused about the procedure for compressing the cylinders to allow for the new pads and also for the handbrake adjustment procedure. All tips gratefully recieved
Xaccers
x 188
Unread post by Xaccers »
Once you've got the old pads out, you'll see that on the piston there's a + cut out of it's face.
Get one of the old pads or a suitable flat rod, and stick it across the face of the piston in two of the notches.
Rotate the piston clockwise to screw it back in.
It takes a while to wind it back all the way.
DIY sphere tool
x 5673
Xac wrote:Once you've got the old pads out, you'll see that on the piston there's a + cut out of it's face.
Aren't they handed Xac, one going clockwise and the other counterclockwise?
rory_perrett
Unread post by rory_perrett »
Nope - not handed, both screw in clockwise.
sadie
Thanks for the help Xac, V useful. Still a bit confused re handbrake cable adjustment. Any help gratefully received
rory_perrett
Hand brake should sort itself out. It is self adjusting. Operate the foot brake a few times and then the hand brake.
