I wanted to test a five pin relay. Usually I would energise the coil, listen for the click then test the switched pins for continuity.
However, when I touched the coil (85 & 86) with 12v it sparks and no click can be heard. I don't want to leave 12v connected in case it shorted my battery. I did read that anything below 50 ohms across the coil indicates it's duff. I get 0.6ohms. Can anyone confirm it's a dead relay given the info above please?
Relay testing
addo
- Sara Watson's Stalker
- x 95
MikeT
- x 232
Clogzz
- x 40
