Relay testing
MikeT
x 232
Relay testing
Unread post by MikeT »
I wanted to test a five pin relay. Usually I would energise the coil, listen for the click then test the switched pins for continuity.
However, when I touched the coil (85 & 86) with 12v it sparks and no click can be heard. I don't want to leave 12v connected in case it shorted my battery. I did read that anything below 50 ohms across the coil indicates it's duff. I get 0.6ohms. Can anyone confirm it's a dead relay given the info above please?
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Sounds like it's welded itself on. Cooling fan relay?
Cheers, Adam.
MikeT
x 232
It's not the cooling fan relays no, they've already been tested as good. It's a spare I had - always worth keeping spares but not if they're kaput.
Clogzz
x 40
Unread post by Clogzz »
anyone confirm
Confirming that the coil is shorted, and probably a crispy black. :twisted:
DC operated relay coils have high resistance, and I’ve got the figure of 200 Ohms in mind.
MikeT
x 232
Ok, thanks for confirming my suspicions.
