Noisy air con
reblack68
Noisy air con
Unread post by reblack68 »
Car is a 1997 Xantia 1.9TD
At the weekend it started making a tinkling noise from the belt area. At idle the noise disappeared when I turned the air con on, though there was still some noise at higher revs. I turned the centre of the pulley by hand and it does feel rough so I think it's fairly conclusive.
The question is, what can I do about it? Can I dismantle the air con pulley/clutch and repair it? I don't want to replace the compressor because that would involve splitting the circuit and I wouldn't know if either the replacement or my fitting was OK until I'd paid to have it recharged.
The other alternative is to fit a different belt and bypass the air conditioning altogether, can that be done?
Richard
Care of a 1994 205 D.
KennyW
x 165
Unread post by KennyW »
Richard,
Check Kowalski's entry in the common porblems and fixes for his explaination of the noisy air con pulley/clutch.
Kenny
C3 1.4 petrol (SWMBO)
reblack68
Thanks for that. It looks a bit complicated :shock: I've learned of a 406 with broken engine so I might see if I can get the pulley/bearing off that, it might.
Does anybody know if I can bypass the compressor for now?
Richard
