RAM - part number?
Toby_HDi
x 3
Unread post by Toby_HDi »
Believe it is 509002, listed as Anti-roll jack. Under Anti-roll bar
Toby
Previous:
2004 Peugeot 407 HDi 138 SE Luxury Pack
2001 S2 Xantia HDi 110 SX
2001 Peugeot 406 V6 Coupé
1998 S2 Xantia Activa
2000 S2 Xantia HDi 110 SX
1999 Peugeot 406 2.0 16v Estate
andmcit
x 30
Unread post by andmcit »
Have a rummage around with the different RP number - one comes in at
around 250 quid and I'd love to know what the difference is!!
Andrew
andmcit
x 30
Sorry Mike, I appear to be talking totally bollocks - it's the rear that has a different ram according to the RP number:
000529003 ANTI-ROLL JACK 182.69 GBP 210.09 GBP 210.09 GBP
0000509004 ANTI-ROLL JACK 308.54 GBP 354.82 GBP 354.82 GBP
What's that all about then? Front only lists one fitment.
Andrew
x 8263
superloopy1 wrote: I'm going to renew the flexible pipes to the front ram at the same time.
Like to hazard a guess at the part numbers for these?
I'm seeing what I think are 5270 T0 and 5270 T1, but why are they different?
Something to do with the pressure rating maybe?
They're the right part numbers Mike.
There's two of them on the ram and they're a tad different in length I guess, hence the different part numbers.
Items 7 and 8 are the pipes in the picture below:
DickieG
Monaco's youngest playboy
x 38
Unread post by DickieG »
superloopy1 wrote:I'm going to renew the flexible pipes to the front ram at the same time.
As Jim states, they are the correct numbers and one pipe is longer than the other, which one is longer is not obvious from the diagram. When you fit the new hoses make sure you position them so that they don't rub against the inner wheel arch as that is what causes them to wear out which at about £70+ for the pair makes it worthwhile spending time to achieve.
The new hoses I fitted to Jim's Activa should be fine :lol:
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
