what have i done!
citroen7
what have i done!
Unread post by citroen7 »
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0296835990
put a bid on this as a bit of a joke thinking i was bound to be outbid :(
i am assuming the problem is a sticky rear height corrector but i am happy to be corrected
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
I have done that so many times :)
usually late at night after some wine :twisted:
I cant see ebay at work so cant comment on the car though .... :shock:
Evodad
Unread post by Evodad »
If the suspension's "hard & bouncy", sounds like a classic case of replacement spheres required.
Cheap as chips (almost) & easy to do with the right sphere removal tool.
You just have to remember to have the suspenson on full height to crack the thread before you de-pressurise to change the spheres.
Did mine & oh what a difference.
Cheers,
Roy.
Tourist
Unread post by Tourist »
You accidentally bought a car ... lol :lol:
newmezuk04
Unread post by newmezuk04 »
Ah the veno, one of the best excuses used by most :wink:
vince
x 13
Unread post by vince »
Apart from the abs light being on £130 for a 98 Xantia cant be bad. You can break it and get more than that.
AndersDK
Unread post by AndersDK »
I'd be happy to pay you out - if car parked at Esbjerg ferry harbour ...
Anders (DK) - '90 BX16Image
red_dwarfers
x 58
Re: what have i done!
Unread post by red_dwarfers »
citroen7 wrote:http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0296835990
I :lol: at the bit in bold
Oh dear...could be a nice little project though? I would say height corrector, does look to be rather high. Shouldn't take much to sort it out :wink:
Kev
'19 C4 Cactus 130 Flair
KevMayer
Unread post by KevMayer »
If it's got Hydractive 2 suspension then the rear could be bouncy because either the centre sphere is shot, so the rear is stuck in hard mode. Or, the diode has failed on the rear electrovalve, which also would cause the rear to stay in 'bouncy' hard mode.
Both of these issues is easy to fix.
It's a mk1 so let us know if it's got the sport mode button in front of the height adjuster (next to the handbrake). If it's got the button then it's Hydractive 2.
Cheers, Kev
red_dwarfers
x 58
KevMayer wrote:If it's got Hydractive 2 suspension then the rear could be bouncy because either the centre sphere is shot, so the rear is stuck in hard mode. Or, the diode has failed on the rear electrovalve, which also would cause the rear to stay in 'bouncy' hard mode.
Don't all VSX spec models from the later era come with Climate Control and the 4030 radio?
Kev
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
Whilst there can be differences between UK and Irish specs for Xantia's if that one is to UK spec then its a SX (i.e. non Hydractive) model. A VSX came with alloys, 4030 radio and a leather wheel (which that one doesn't have), whereas an LX wouldn't have the front fogs. A/C became standard on all models in 96.
As far as what's wrong with the car it could simply be a detached plastic link to the height corrector or the corrector itself.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
x 1240
Unread post by Peter.N. »
Although he says the spheres have been replaced I cant see that anything else could make it 'bouncy' unless the ride height is wrong and its hitting the bump stops. Even if the centre sphere is flat, it still shouldn't bounce but it will ride hard. Even if the wrong spheres have been fitted it still shouldn't bounce, sounds like one or both of the replacements have failed.
x 1459
Unread post by xantia_v6 »
It is almost certainly not hydroactive (the steering wheel is the best clue).
My 10p would wager that the wrong psheres have been fitted.
x 94
Unread post by citronut »
in the side view it looks like the rear end has not come up to the corect level,
£150 sqid to supply and fit two rear spheres, sounds a bit extautionate
regards malcolml
citroen7
just spoke to the seller it would appear that quite a lot of work was done for the mot track rod ends etc . it is an sx so i am assuming that it is one of the last mk1s the intention is to pick it up sunday just got to pick up courage to tell the wife :!: as despite having a large driveway it is fast filling up and is begining to look like a scrapyard :D
