Centre console
MikeT
- x 232
Centre console
Are they easy to remove and would it give me a route to the engine bay via, what I call, the gearbox tunnel?
Stempy
It's a bit of a pig to get the hand brake out of the way but it will come out with enough BF&I. I don't recall there being any way into the engine bay without drilling holes. I looked in vain with the hope of finding a through route when I did the matrix.
Lexia ponce
Lexia ponce
KevMayer
To remove the centre console you need to take the front wheels off and release the handbrake cable on both brake callipers.
Working inside the car you can then release the cable from the handbrake lever.
With the cable off you need to lift the handbrake to the vertical and lift the console off over it.
Cheers, Kev
reblack68
MikeT
- x 232
This was what I was told when I asked before so I went off the idea, especially when someone said they drilled through a harness. However, lLast time Citrojim came by he suggested under the tunnelStempy wrote:...I don't recall there being any way into the engine bay without drilling holes....
That's handy, it's currently sitting on axle stands with RH wheel offKevMayer wrote:To remove the centre console you need to take the front wheels off and release the handbrake cable on both brake callipers.
addo
- Sara Watson's Stalker
- x 95
MikeT
- x 232
DickieG
- Monaco's youngest playboy
- x 33
Oh good lord no don't go to all that hassleKevMayer wrote:To remove the centre console you need to take the front wheels off and release the handbrake cable on both brake callipers.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
- x 1052
I was just thinking the same thing, I would never dream of going to the hassle of disconnecting the handbrake cables to remove the centre console, as dickie says foot hard on the brake & a good hard yank on the handbrake does the trick.DickieG wrote:Oh good lord no don't go to all that hassleKevMayer wrote:To remove the centre console you need to take the front wheels off and release the handbrake cable on both brake callipers.simply press hard on the footbrake to assist in pulling up the handbrake high enough to allow the console to slip over the top of it. I've used this method on several Xantia's with total success
KevMayer
I've had my centre console out 2 times on a Xantia and disconnecting the brake cable was the only way I could think of to free up the lever enough to pull the console over it.
It was easy enough to disengage the handbrake cable. So easy that I'd do it the same way if I have to remove the console again.
I don't like giving handbrakes a good hard yank because of the risk of upsetting the adjustment of the cable or stretching an old cable.
Cheers, Kev
