Centre console
MikeT
x 232
Centre console
Unread post by MikeT »
Are they easy to remove and would it give me a route to the engine bay via, what I call, the gearbox tunnel?
Stempy
Unread post by Stempy »
It's a bit of a pig to get the hand brake out of the way but it will come out with enough BF&I. I don't recall there being any way into the engine bay without drilling holes. I looked in vain with the hope of finding a through route when I did the matrix.
Lexia ponce
KevMayer
Unread post by KevMayer »
To remove the centre console you need to take the front wheels off and release the handbrake cable on both brake callipers.
Working inside the car you can then release the cable from the handbrake lever.
With the cable off you need to lift the handbrake to the vertical and lift the console off over it.
Cheers, Kev
reblack68
Unread post by reblack68 »
I tried to find a way through when I was installing a 12S socket but I ended up connecting the cable into the fusebox.
Richard
No French cars of my own at present.
Care of a 1994 205 D.
MikeT
x 232
Stempy wrote:...I don't recall there being any way into the engine bay without drilling holes....
This was what I was told when I asked before so I went off the idea, especially when someone said they drilled through a harness. However, lLast time Citrojim came by he suggested under the tunnel :!: I was already considering the coin tray and ashtray as gauge space donors so it would be a neat solution to pass through there. Heat shields may be needed but that's a small price to pay considering the alternatives I think.
KevMayer wrote:To remove the centre console you need to take the front wheels off and release the handbrake cable on both brake callipers.
That's handy, it's currently sitting on axle stands with RH wheel off :lol: Cheers for the method, Kev.
addo
Sara Watson's Stalker
x 95
Unread post by addo »
I used the other approach detailed on this site, for the handbrake - loosened the three mount bolts after lifting the console slightly. Then you can tip it forward and unhook the cable. When reassembling, you trim away more carpet/underlay around the bolt positions.
Regards, Adam.
MikeT
x 232
I'll let my nephew decide which method he wants to use then 8) Thanks addo
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
Oh good lord no don't go to all that hassle :shock: simply press hard on the footbrake to assist in pulling up the handbrake high enough to allow the console to slip over the top of it. I've used this method on several Xantia's with total success :lol:
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
x 1053
Unread post by wheeler »
I was just thinking the same thing, I would never dream of going to the hassle of disconnecting the handbrake cables to remove the centre console, as dickie says foot hard on the brake & a good hard yank on the handbrake does the trick.
KevMayer
I've had my centre console out 2 times on a Xantia and disconnecting the brake cable was the only way I could think of to free up the lever enough to pull the console over it.
It was easy enough to disengage the handbrake cable. So easy that I'd do it the same way if I have to remove the console again.
I don't like giving handbrakes a good hard yank because of the risk of upsetting the adjustment of the cable or stretching an old cable.
Cheers, Kev
