Peugeot Partner Gearbox
Post Reply
evilally
My Cars:
Post by evilally »
Struggling to find any info on these on the net, what kind of gearbox does the 2.5 diesel use? BE3? Would it be a suitable doner for my 405? It's a 1997......
'97 406 1.9TD, 314k.
reblack68
My Cars:
Post by reblack68 »
Are you sure you're talking about a Partner with a 2.5 Diesel?
Richard
Care of a 1994 205 D.
My Cars: Bluebell the AX, Polly the C3 Picasso, Pix the Nissan Pixo, Propel the duathlon bike, TCR Pro the road bike and Fuji the TT bike...
x 6176
Contact:
Post by CitroJim »
If it is a 2.5 then it'll most likely use the MG 'box (I think) as fitted to the 2.5TD Citroen XM. It's similar to the ML 'box used with the 2.1TD
Sadly, not really suitable as a donor for the 405 which uses a BE3.
What's wrong with your 405 'box?
evilally
My Cars:
Post by evilally »
Yes, a Peugeot Partner 2.5 diesel. I saw a relatively low miler being broken for spares locally, I thought it might be a suitable doner. I posted a thread about my 405 gearbox a while ago, it's crunching 3rd which I presume is the usual worn synchro. I thought maybe the Partner used a BE3 since it seems to be a common gearbox.
AndersDK
My Cars:
Post by AndersDK »
There never was a Peugeot Partner with the 2.5D engine. Must be a missprint.
Bet it should be a Boxer.
Anders (DK) - '90 BX16Image
x 6176
Contact:
Post by CitroJim »
evilally wrote:I posted a thread about my 405 gearbox a while ago, it's crunching 3rd which I presume is the usual worn synchro.
Best anyway to get a replacement 'box from another 405 or 1.9TD Xantia as there are a plethora of of different BE3 'boxes around with different gearsets and final drives. There are no external markings to tell you and van ratios may not suit a car.
Either that or get any old BE3 with known good synchros and use it as a donor to rebuild yours. The synchros are all the same and not as hard as you think to swap.
evilally
My Cars:
Post by evilally »
Well, I just picked up a 1.9TD 306 gearbox for a fiver. In good working order (apparently). I'll maybe look at getting it swapped when the weather gets better, wish me luck!
Post Reply
