RP Numbers
surfer
RP Numbers
Unread post by surfer »
Dumb question, but I've only had the car for one month ~ please make allowances:
What exactly is the RP number, and where it is located?
Is it with the vin plates??
Thanks,
Simon.
x 1490
The RP number is number which tells you on exactly which day the car was built. It started at 0001 way back (70's I think), and is increased by 1 each day.
See this link which describes it in detail, and includes a calculator:
http://www.tramontana.co.hu/citroen/mai ... ORGAscript
It is usually stencilled on the bodywork somewhere under the bonnet - around an inner wing / suspenion turret / bulkhed. Where depends on what model, when it was made, how hungover the stencilling guy was etc etc. You may find it on the doorpost on some older models.
Richard
Edited by - RichardW on 19 Feb 2003 17:08:47
x 1055
Unread post by wheeler »
if its a newer model (from about V reg onwards) then it is on the sticker on the door pillar with the tyre pressures on it starting with a 0 and ending with two letters eg 0****CA. the two letters is the factory it was made in.
blueboy2001
Unread post by blueboy2001 »
On a Xantia its to be found on the offside (drivers) suspension turret. On mine its above the colour code print in yellow paint. Most Xantia's start with a 6*** number.
On newer cars (eg. my 2002 Xsara) it is on the tyre pressure sticker on the drivers doorframe. The bottom set of codes denotes the RP or ORGA number.
Edited by - blueboy2001 on 20 Feb 2003 00:40:56
surfer
Thanks for that chaps.
Shame there isn't an extra number to go with that, which indicates how well the car was 'made'.
Simon.
