Dumb question, but I've only had the car for one month ~ please make allowances:
What exactly is the RP number, and where it is located?
Is it with the vin plates??
Thanks,
Simon.
RP Numbers
- x 1432
The RP number is number which tells you on exactly which day the car was built. It started at 0001 way back (70's I think), and is increased by 1 each day.
See this link which describes it in detail, and includes a calculator:
http://www.tramontana.co.hu/citroen/mai ... ORGAscript
It is usually stencilled on the bodywork somewhere under the bonnet - around an inner wing / suspenion turret / bulkhed. Where depends on what model, when it was made, how hungover the stencilling guy was etc etc. You may find it on the doorpost on some older models.
Richard
Edited by - RichardW on 19 Feb 2003 17:08:47
Richard
- x 1044
blueboy2001
On a Xantia its to be found on the offside (drivers) suspension turret. On mine its above the colour code print in yellow paint. Most Xantia's start with a 6*** number.
On newer cars (eg. my 2002 Xsara) it is on the tyre pressure sticker on the drivers doorframe. The bottom set of codes denotes the RP or ORGA number.
Edited by - blueboy2001 on 20 Feb 2003 00:40:56
surfer
