Dreaded Management Light
pikecrazy
Unread post by pikecrazy »
Well this afternoon when i turned the engine off it seemed to run on for a couple of seconds. :?
Noticed the light came on mmmmm so i pulled away but engine wouldn't rev over 2000 rpm. :cry:
Thinking it could be a fuel problem i checked filter but it was ok.
Any ideas folks
:evil:
2013 Berlingo Multispace 1.6 XTR 115bhp
2003 2:0 HDI Dispatch Van 186000 miles......gone
2000 Xantia Hdi 90bhp Forte Estate 97000 miles gone..........to heaven
New High pressure Fuel Pump and Patched ECU , Blower Module fixed by CitroJim :-)
red_dwarfers
x 58
Unread post by red_dwarfers »
I would be tempted to say that its gone into limp home mode.
I think that generally points to dud/dying sensor, I know a member of my family had this problem a while back with their 406 HDI, that was one of the sensor.
there might be something lurking around the forum, try the search function.
Kev
'19 C4 Cactus 130 Flair
nick
Unread post by nick »
If the engine runs on it could be the pressure regulator on the high pressure pump sticking. Equally I think the pressure sensor on the fuel rail could cause the same problem.
Its quite easy to take the pressure regulator off the pump to have a look. Two torx screws to undo it, then it just pulls out the back of the pump. Be very careful not to introduce any dirt into the system though.
addo
Sara Watson's Stalker
x 95
Unread post by addo »
For something to run on and not rev out, the other issue could be heat. Lack of water may not show on the temperature gauge... How's coolant level in the overflow tank?
Regards, Adam.
howiedean
Re: Dreaded Management Light
Unread post by howiedean »
pikecrazy wrote:Well this afternoon when i turned the engine off it seemed to run on for a couple of seconds. :?
Any ideas folks
:evil:
pikecrazy,
What did you have to do to fix your car. I noticed that you have a patched ECU, what was that done for?
Regards
Howie
2006 Fiat Idea Dynamic 1.3 Multijet
2010 Renault Laguna Dynamique tom tom 2.0 DCI 130
C5 VTR 2l 8v HDI Estate 112000 miles gone
Kia Rio 2007 1.5 CRDI 62,000 miles gone
2001 Dodge Durango 4.7 V8 170,000 miles gone
1999 Ford Crown Victoria 4.6 V8 151,000 miles gone
pikecrazy
howiedean wrote:
pikecrazy,
Regards
It just seemed to clear itself after i removed the fuel filter :?
The patched ecu was related to the Fuel Pump I'm not quite sure what was done.
howiedean
pikecrazy wrote:
howiedean wrote:
Regards
Thanks pikecrazy,
The new high pressure pump was a fault after this issue then? :twisted:
Howie
pikecrazy
howiedean wrote: The new high pressure pump was a fault after this issue then? :twisted:
Nope well before :cry:
