hi guys
i have a problem with the clutch/gearbox on my 99 1.6 scenic when i first start off from cold everything is fine then after she gets warmed up the gearchanging gets hard, notchy is the word but can still change gears i was wondering if there was anyway can i adjust the clutch cable on my car as its not hydrulic ive found the cable but can see no way of adjusting it.
thanks in advance
pete........................
scenic clutch problem
pete@co.uk
Drives
51 Reg Citroen C5 SX 2.0 16v
pete@co.uk
pete@co.uk
jgra1
- (Donor 2021)
- x 36
pete@co.uk
ashleyward
HI I had a similar problem about a year ago, then i changed the gearbox oil for some premium stuff and problem solved.
My scenic had done about 58000miles when i changed the oil and im now well in to the high 70K area with absolutly no issues
the gearbox oil costs about £10 to £15 per liter tho and you will need to buy 4 liters as its a 3.5liter box.
