scenic clutch problem
This is the Forum for all your Renault Technical Questions, Problems or Advice.
[email protected]
Unread post by [email protected] »
hi guys
i have a problem with the clutch/gearbox on my 99 1.6 scenic when i first start off from cold everything is fine then after she gets warmed up the gearchanging gets hard, notchy is the word but can still change gears i was wondering if there was anyway can i adjust the clutch cable on my car as its not hydrulic ive found the cable but can see no way of adjusting it.
thanks in advance
pete........................
Drives
51 Reg Citroen C5 SX 2.0 16v
[email protected]
hi agian all
i just want to know how to adjust the clutch on my scenic ?
regards
pete.............................
Drives
[email protected]
hi guys
there must be someone out there who can help me with this its a 99 scenic (old shape 1.6) and the clutch is not hydrulic it has a cable and i just need to know how to adjust the cable :?
Drives
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
hi Pete, I cant help with clutch cable :(
but check/change oil in box, as a heat related change problem sounds more like oil to me...
John
[email protected]
hi john
thanks for your reply ill get the gearbox oil checked and topped up tomorrow see if it cures the problem
regards
pete...................................
Drives
ashleyward
Unread post by ashleyward »
HI I had a similar problem about a year ago, then i changed the gearbox oil for some premium stuff and problem solved.
My scenic had done about 58000miles when i changed the oil and im now well in to the high 70K area with absolutly no issues :)
the gearbox oil costs about £10 to £15 per liter tho and you will need to buy 4 liters as its a 3.5liter box.
