I'm was having trouble starting my Xantia, with 3 of the glow plugs recently replaced I suspected air in the fuel. When I loosened the fuel feed and squeezed the prime bulb, bubbly fuel came out. When I re-tightened the fuel line and squeezed the bulb, diesel came pouring out round the clamp on the bulb.
Could this be the problem? or can Xantias run ok with primer bulb leaking?
Cheers
Fangy.
leaky primer bulb
fangy
leaky primer bulb
95 Xantia VSX 1.9td, Fj1100, z-750 hardtail
MikeT
- x 232
fangy
juraj
AndersDK
