leaky primer bulb
fangy
leaky primer bulb
Unread post by fangy »
Hi,
I'm was having trouble starting my Xantia, with 3 of the glow plugs recently replaced I suspected air in the fuel. When I loosened the fuel feed and squeezed the prime bulb, bubbly fuel came out. When I re-tightened the fuel line and squeezed the bulb, diesel came pouring out round the clamp on the bulb.
Could this be the problem? or can Xantias run ok with primer bulb leaking?
Cheers
Fangy.
95 Xantia VSX 1.9td, Fj1100, z-750 hardtail
MikeT
x 232
Unread post by MikeT »
It's certainly worth rectifying and could well be the cause.
elma
x 287
Unread post by elma »
I second that.
admiral51
x 390
Unread post by admiral51 »
Have a look at this thread
air can cause a great deal of problems in the fuel system :) :)
thunk places like b+q screwfix sell the priming bulbs same type for the central heating systems
Colin
fangy
Thanks for the replies.
Cant seem to find a proper Xantia bulb. Does anyone know if a marine bulb will do, and if so what diameter it should be, ie, small/medium 8mm, or large 10mm.
Many thanks,
Fangy
juraj
Unread post by juraj »
hi
they are 8mm fittings,
my priming bulb has a faulty one way valve, i got a very nice little one way valve only form ebay for aboyt £5.50 (inc. postage) put it in after the bulb,
bye
AndersDK
Unread post by AndersDK »
marine shops/fitters usually have these primer bulbs ready fitted with non return valve and a short length of fuel hose attached both ends. Cheap standard component in marine communities ...
Anders (DK) - '90 BX16Image
